I'm working with an LPC1768(FBD100) and need to connect to a PC through a serial USB. As a starting point, I used the sample package USB virtual com port.
Installed packages:
My code:
#include "includes.h" int main (void) { MenuEntryVType* MenuEntry; GUI_Init(); WM_SetCreateFlags(WM_CF_MEMDEV); FRAMEWIN_SetDefaultSkinClassic(); PROGBAR_SetDefaultSkinClassic(); SCROLLBAR_SetDefaultSkinClassic(); FRAMEWIN_SetDefaultFont(StdFont); InitOutputs(); InitADCs(); InitDAC(); InitPWM(100); InitI2C(); GetConfig(); osDelay(1500); // Works as expected ; new COMx device shows in dev manager. USBD_Initialize (0U); // USB Device 0 Initialization USBD_Connect (0U); // USB Device 0 Connect // menu handling code // actual functionality start servos, etc.) // does not get executed. Why? return 0; }
Why does USBD_Connect() hang? no code gets executed past that point; the lpc1768 does connect, however, to the PC:
rl_usb.h contains the definitions of USBD_Initialize() and USBD_Connect():
/// \brief Initialize USB Device stack and controller /// \param[in] device index of USB Device. /// \return status code that indicates the execution status of the function as defined with \ref usbStatus. extern usbStatus USBD_Initialize (uint8_t device); /// \brief Activate pull-up on D+ or D- line to signal USB Device connection on USB Bus /// \param[in] device index of USB Device. /// \return status code that indicates the execution status of the function as defined with \ref usbStatus. extern usbStatus USBD_Connect (uint8_t device);
These are function declarations; I don't know where the implementations are (likely in USB_CM3_L.lib).
Read/write functions are defined in USBD_User_CDC_ACM_UART_0.c
/*------------------------------------------------------------------------------ * MDK Middleware - Component ::USB:Device * Copyright (c) 2004-2019 ARM Germany GmbH. All rights reserved. *------------------------------------------------------------------------------ * Name: USBD_User_CDC_ACM_UART_0.c * Purpose: USB Device Communication Device Class (CDC) * Abstract Control Model (ACM) USB <-> UART Bridge User module * Rev.: V1.0.3 *----------------------------------------------------------------------------*/ /** * \addtogroup usbd_cdcFunctions * * USBD_User_CDC_ACM_UART_0.c implements the application specific * functionality of the CDC ACM class and is used to demonstrate a USB <-> UART * bridge. All data received on USB is transmitted on UART and all data * received on UART is transmitted on USB. * * Details of operation: * UART -> USB: * Initial reception on UART is started after the USB Host sets line coding * with SetLineCoding command. Having received a full UART buffer, any * new reception is restarted on the same buffer. Any data received on * the UART is sent over USB using the CDC0_ACM_UART_to_USB_Thread thread. * USB -> UART: * While the UART transmit is not busy, data transmission on the UART is * started in the USBD_CDC0_ACM_DataReceived callback as soon as data is * received on the USB. Further data received on USB is transmitted on * UART in the UART callback routine until there is no more data available. * In this case, the next UART transmit is restarted from the * USBD_CDC0_ACM_DataReceived callback as soon as new data is received * on the USB. * * The following constants in this module affect the module functionality: * * - UART_PORT: specifies UART Port * default value: 0 (=UART0) * - UART_BUFFER_SIZE: specifies UART data Buffer Size * default value: 512 * * Notes: * If the USB is slower than the UART, data can get lost. This may happen * when USB is pausing during data reception because of the USB Host being * too loaded with other tasks and not polling the Bulk IN Endpoint often * enough (up to 2 seconds of gap in polling Bulk IN Endpoint may occur). * This problem can be solved by using a large enough UART buffer to * compensate up to a few seconds of received UART data or by using UART * flow control. * If the device that receives the UART data (usually a PC) is too loaded * with other tasks it can also loose UART data. This problem can only be * solved by using UART flow control. * * This file has to be adapted in case of UART flow control usage. */ //! [code_USBD_User_CDC_ACM] #include <stdbool.h> #include "rl_usb.h" #if defined(RTE_CMSIS_RTOS2) #include "cmsis_os2.h" #if defined(RTE_CMSIS_RTOS2_RTX5) #include "rtx_os.h" #endif #endif #if defined(RTE_CMSIS_RTOS) #include "cmsis_os.h" #endif #include "Driver_USART.h" // UART Configuration ---------------------------------------------------------- #define UART_PORT 1 // UART Port number #define UART_BUFFER_SIZE 512 // UART Buffer Size //------------------------------------------------------------------------------ #define _UART_Driver_(n) Driver_USART##n #define UART_Driver_(n) _UART_Driver_(n) extern ARM_DRIVER_USART UART_Driver_(UART_PORT); #define ptrUART (&UART_Driver_(UART_PORT)) // External functions #ifdef USB_CMSIS_RTOS extern void CDC0_ACM_UART_to_USB_Thread (void const *arg) __attribute((noreturn)); #endif // Local Variables static uint8_t uart_rx_buf[UART_BUFFER_SIZE]; static uint8_t uart_tx_buf[UART_BUFFER_SIZE]; static volatile int32_t uart_rx_cnt = 0; static volatile int32_t usb_tx_cnt = 0; static void *cdc_acm_bridge_tid = 0U; static CDC_LINE_CODING cdc_acm_line_coding = { 0U, 0U, 0U, 0U }; // Called when UART has transmitted or received requested number of bytes. // \param[in] event UART event // - ARM_USART_EVENT_SEND_COMPLETE: all requested data was sent // - ARM_USART_EVENT_RECEIVE_COMPLETE: all requested data was received static void UART_Callback (uint32_t event) { int32_t cnt; if (event & ARM_USART_EVENT_SEND_COMPLETE) { // USB -> UART cnt = USBD_CDC_ACM_ReadData(0U, uart_tx_buf, UART_BUFFER_SIZE); if (cnt > 0) { ptrUART->Send(uart_tx_buf, (uint32_t)(cnt)); } } if (event & ARM_USART_EVENT_RECEIVE_COMPLETE) { // UART data received, restart new reception uart_rx_cnt += UART_BUFFER_SIZE; ptrUART->Receive(uart_rx_buf, UART_BUFFER_SIZE); } } // Thread: Sends data received on UART to USB // \param[in] arg not used. #ifdef USB_CMSIS_RTOS2 __NO_RETURN static void CDC0_ACM_UART_to_USB_Thread (void *arg) { #else __NO_RETURN void CDC0_ACM_UART_to_USB_Thread (void const *arg) { #endif int32_t cnt, cnt_to_wrap; (void)(arg); while (1) { // UART - > USB if (ptrUART->GetStatus().rx_busy != 0U) { cnt = uart_rx_cnt; cnt += ptrUART->GetRxCount(); cnt -= usb_tx_cnt; if (cnt >= UART_BUFFER_SIZE) { // Dump data received on UART if USB is not consuming fast enough usb_tx_cnt += cnt; cnt = 0U; } if (cnt > 0) { cnt_to_wrap = (int32_t)(UART_BUFFER_SIZE - ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1))); if (cnt > cnt_to_wrap) { cnt = cnt_to_wrap; } cnt = USBD_CDC_ACM_WriteData(0U, (uart_rx_buf + ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1))), cnt); if (cnt > 0) { usb_tx_cnt += cnt; } } } osDelay(10U); } } #ifdef USB_CMSIS_RTOS2 #ifdef USB_CMSIS_RTOS2_RTX5 static osRtxThread_t cdc0_acm_uart_to_usb_thread_cb_mem __SECTION(.bss.os.thread.cb); static uint64_t cdc0_acm_uart_to_usb_thread_stack_mem[512U / 8U] __SECTION(.bss.os.thread.stack); #endif static const osThreadAttr_t cdc0_acm_uart_to_usb_thread_attr = { "CDC0_ACM_UART_to_USB_Thread", 0U, #ifdef USB_CMSIS_RTOS2_RTX5 &cdc0_acm_uart_to_usb_thread_cb_mem, sizeof(osRtxThread_t), &cdc0_acm_uart_to_usb_thread_stack_mem[0], #else NULL, 0U, NULL, #endif 512U, osPriorityNormal, 0U, 0U }; #else extern const osThreadDef_t os_thread_def_CDC0_ACM_UART_to_USB_Thread; osThreadDef (CDC0_ACM_UART_to_USB_Thread, osPriorityNormal, 1U, 0U); #endif // CDC ACM Callbacks ----------------------------------------------------------- // Called when new data was received from the USB Host. // \param[in] len number of bytes available to read. void USBD_CDC0_ACM_DataReceived (uint32_t len) { int32_t cnt; (void)(len); if (ptrUART->GetStatus().tx_busy == 0U) { // Start USB -> UART cnt = USBD_CDC_ACM_ReadData(0U, uart_tx_buf, UART_BUFFER_SIZE); if (cnt > 0) { ptrUART->Send(uart_tx_buf, (uint32_t)(cnt)); } } } // Called during USBD_Initialize to initialize the USB CDC class instance (ACM). void USBD_CDC0_ACM_Initialize (void) { ptrUART->Initialize (UART_Callback); ptrUART->PowerControl (ARM_POWER_FULL); #ifdef USB_CMSIS_RTOS2 cdc_acm_bridge_tid = osThreadNew (CDC0_ACM_UART_to_USB_Thread, NULL, &cdc0_acm_uart_to_usb_thread_attr); #else cdc_acm_bridge_tid = osThreadCreate (osThread (CDC0_ACM_UART_to_USB_Thread), NULL); #endif } // Called during USBD_Uninitialize to de-initialize the USB CDC class instance (ACM). void USBD_CDC0_ACM_Uninitialize (void) { if (osThreadTerminate (cdc_acm_bridge_tid) == osOK) { cdc_acm_bridge_tid = NULL; } ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); ptrUART->PowerControl (ARM_POWER_OFF); ptrUART->Uninitialize (); } // Called upon USB Bus Reset Event. void USBD_CDC0_ACM_Reset (void) { ptrUART->Control (ARM_USART_ABORT_SEND, 0U); ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); } // Called upon USB Host request to change communication settings. // \param[in] line_coding pointer to CDC_LINE_CODING structure. // \return true set line coding request processed. // \return false set line coding request not supported or not processed. bool USBD_CDC0_ACM_SetLineCoding (const CDC_LINE_CODING *line_coding) { uint32_t data_bits = 0U, parity = 0U, stop_bits = 0U; int32_t status; ptrUART->Control (ARM_USART_ABORT_SEND, 0U); ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); ptrUART->Control (ARM_USART_CONTROL_TX, 0U); ptrUART->Control (ARM_USART_CONTROL_RX, 0U); switch (line_coding->bCharFormat) { case 0: // 1 Stop bit stop_bits = ARM_USART_STOP_BITS_1; break; case 1: // 1.5 Stop bits stop_bits = ARM_USART_STOP_BITS_1_5; break; case 2: // 2 Stop bits stop_bits = ARM_USART_STOP_BITS_2; } switch (line_coding->bParityType) { case 0: // None parity = ARM_USART_PARITY_NONE; break; case 1: // Odd parity = ARM_USART_PARITY_ODD; break; case 2: // Even parity = ARM_USART_PARITY_EVEN; break; default: return false; } switch (line_coding->bDataBits) { case 5: data_bits = ARM_USART_DATA_BITS_5; break; case 6: data_bits = ARM_USART_DATA_BITS_6; break; case 7: data_bits = ARM_USART_DATA_BITS_7; break; case 8: data_bits = ARM_USART_DATA_BITS_8; break; default: return false; } status = ptrUART->Control(ARM_USART_MODE_ASYNCHRONOUS | data_bits | parity | stop_bits | ARM_USART_FLOW_CONTROL_NONE , line_coding->dwDTERate ); if (status != ARM_DRIVER_OK) { return false; } // Store requested settings to local variable cdc_acm_line_coding = *line_coding; uart_rx_cnt = 0; usb_tx_cnt = 0; ptrUART->Control (ARM_USART_CONTROL_TX, 1U); ptrUART->Control (ARM_USART_CONTROL_RX, 1U); ptrUART->Receive (uart_rx_buf, UART_BUFFER_SIZE); return true; } // Called upon USB Host request to retrieve communication settings. // \param[out] line_coding pointer to CDC_LINE_CODING structure. // \return true get line coding request processed. // \return false get line coding request not supported or not processed. bool USBD_CDC0_ACM_GetLineCoding (CDC_LINE_CODING *line_coding) { // Load settings from ones stored on USBD_CDC0_ACM_SetLineCoding callback *line_coding = cdc_acm_line_coding; return true; } // Called upon USB Host request to set control line states. // \param [in] state control line settings bitmap. // - bit 0: DTR state // - bit 1: RTS state // \return true set control line state request processed. // \return false set control line state request not supported or not processed. bool USBD_CDC0_ACM_SetControlLineState (uint16_t state) { // Add code for set control line state (void)(state); return true; } //! [code_USBD_User_CDC_ACM]
Is it possible to run the lpc1768 as a USB listener and also perform a set of tasks in parallel? If yes, how should I go about it?
Hi.
You haven't specified the board or USB layout you are using, but as a starting point I suggest USB Device Virtual COM example for the Keil MCB1700 board.
Schematic is here: www.keil.com/.../mcb1700-schematics.pdf
Example is in the LC1700_DFP, pack, once installed, the example can be found in path like below:
c:\Keil_v5\ARM\PACK\Keil\LPC1700_DFP\2.6.0\Boards\Keil\MCB1700\Middleware\USB\Device\VirtualCOM\
"I'm working with an LPC1768(FBD100) ... " USB layout: P1.30, P0.29, P0.30. I've read the schematic and have already integrated the example into my code; the problem is that I don't know if the mcu can listen on a usb port while running other threads.
Of course it can, USB functionality runs in separate threads so other threads can execute in parallel.
When I create a separate thread that does USBD_Initialize() and USBD_Connect() I don't see the device as a serial connection in device manager (every other thread executes successfully). There seems to be an issue in that code that should execute in threads does not if the USB related functionality is run before it. If the USB related logic is placed after the initial logic it does not execute either inside/outside a thread.
Milorad Cvjetkovic said:Of course it can
Indeed!
It would be pretty useless if it didn't!
Before jumping into the complexities of USB. have you done some basic projects on this chip to gain familiarity with it and the tools ?
Also, the USB stuff is proprietary to NXP - nothing to do with ARM or Keil - so you'd be better asking NXP about specific details of getting their USB in their chip to work ...
https://community.nxp.com/
Don't NXP provide any examples, demos, etc ... ?
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mcus/lpc1700-cortex-m3/512kb-flash-64kb-sram-ethernet-usb-lqfp100-package:LPC1768FBD100
You should analyze the code to better understand what and how to achieve what you want to achieve.
Anyways, when you call USBD_Initialize it actually creates all the thread responsible for the USB handling behind the scenes, you could take a look at RTOS view to see which threads are running (http://www2.keil.com/mdk5/cmsis/rtx/rtos-awareness).
You do not have to call USBD_Initialize from your thread, it is irrelevant.
You should also analyze if you have enough of RTOS resources configured in RTX_Config.h file for all the threads and any other RTOS objects you are using in your project.
Anyways, I would start from the MCB1700 VirtualCOM example, if it works, I would then add 1 new thread that just increments the counter and see if that works and then start adding additional functionality.
Took over a project (haven't worked with lpcxxxx; not new to embedded, however) that has to be extended with a polling mechanism that can only use USB. I've checked the samples but didn't see any USB specific code (maybe haven't looked hard enough). The sample code from keil works as expected with the exception that no further threads can be created once USB_Connect() is called.
