I've been struggling to set up the event recorder. I narrowed the problem down to the RAM that I am allocating to the device. As soon as I do, the ethernet connection of the controller stops working.
Here is my configuration
I get no complaints or warnings. The RAM section from 0x20000000 to 0x20008000 is not reserved, but as soon as I restart the controller ethernet does not connect and thus nothing is working anymore. Any ideas?
Take a look into your .map file for a clue.
I did that. At the end it lists all the allocated memory sections. I made sure to be outside of all sections and still get the same result.
