Rebuild started: Project: asm4-1*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Rebuild target 'Target 1'"asm4-1.s", line 6: Error: A1167E: Invalid line start 6 00000000 ??1 Error, 0 Warningsassembling asm4-1.s...linking....\Objects\asm4-1.axf: error: L6002U: Could not open file .\objects\asm4-1.o: No such file or directoryNot enough information to list image symbols.Not enough information to list load addresses in the image map.Finished: 2 information, 0 warning, 0 error and 1 fatal error messages.".\Objects\asm4-1.axf" - 1 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:01this was the error messagealso whenever i use debugger the first time it just shows debug error message but the second time i get not responding message and keil just shuts down itself. Please help
1. What's the Keil product in use?
2. What version of this product is in use?
3. What's the target (controller) in use?
PShrestha said:"asm4-1.s", line 6: Error: A1167E: Invalid line start
So open the file named "asm4-1.s" in your editor, and look at line 6 - is it valid.
Note that you can very simply do that by double-clicking on the error message.
Are you sure that this file is an ARM Assembler file - and not, say, a GCC assembler file ... ?
http://www.keil.com/support/man/docs/armasm/
PShrestha said:.\Objects\asm4-1.axf: error: L6002U: Could not open file .\objects\asm4-1.o: No such file or directory
asm4-1.o would be the object file generated when asm4-1.s is translated successfully.
Obviously, because there was an error in the assembly, there would have been no object file generated - hence this error.
