Rebuild started: Project: asm4-1*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Rebuild target 'Target 1'"asm4-1.s", line 6: Error: A1167E: Invalid line start 6 00000000 ??1 Error, 0 Warningsassembling asm4-1.s...linking....\Objects\asm4-1.axf: error: L6002U: Could not open file .\objects\asm4-1.o: No such file or directoryNot enough information to list image symbols.Not enough information to list load addresses in the image map.Finished: 2 information, 0 warning, 0 error and 1 fatal error messages.".\Objects\asm4-1.axf" - 1 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:01this was the error messagealso whenever i use debugger the first time it just shows debug error message but the second time i get not responding message and keil just shuts down itself. Please help
PShrestha said:"asm4-1.s", line 6: Error: A1167E: Invalid line start
So open the file named "asm4-1.s" in your editor, and look at line 6 - is it valid.
Note that you can very simply do that by double-clicking on the error message.
Are you sure that this file is an ARM Assembler file - and not, say, a GCC assembler file ... ?
http://www.keil.com/support/man/docs/armasm/
PShrestha said:.\Objects\asm4-1.axf: error: L6002U: Could not open file .\objects\asm4-1.o: No such file or directory
asm4-1.o would be the object file generated when asm4-1.s is translated successfully.
Obviously, because there was an error in the assembly, there would have been no object file generated - hence this error.
