I am trying to flash code onto the STM32F303 microcontroller on Keil uVision5 MDK-ARM v5.31 using the ULINK2 JTAG debugger. I have the latest packs for the STM32xx_DFP (v2.1.0). Now, whenever I try entering Debug Mode on Keil, I get a "ULINK2/ME - Cortex-M Error" popup message saying: "PDSC: Sequence Execution failed".
Below is the description in the 'Build Output' section:
Cannot access Memory (@ 0xe00fffe4, Read, Acc Size: 4 Byte)
File : C:\Users\<username>\AppData\Local\Arm\Packs\Keil\STM32F3xx_DFP\2.1.0\Keil.STM32F3xx_DFP.pdsc
Sequence : DebugDeviceUnlock -> CheckID
Context : Item #0: <block>::Line 11
Expression : "\<username>\AppData\Local\Arm\Packs\Keil\STM32F3xx_DFP\2.1.0\Keil.STM32F3xx_DFP.pdsc"
E310 : Debug access failed - cannot read address 0xE00FFFE4 (accsize, '4', AP '0x00000000')
Cannot access Memory (@ 0x00000000, Write, Acc Size: 4 Byte)
Error: Flash Download failed - Target DLL has been cancelled
My Keil uVision software works fine with the STM32F303 series until a week ago. I am certain my JTAG debugger is not the issue because I am able to run Debug Mode using the JTAG debugger on a custom PCB with an STM32F410 chip. I also do not have issues when uploading code to the STM32F303RE Nucleo board through ST-Link (so I don't think the issue is with the STM32F3xx_DFP pack). Furthermore, this issue also occurs on the STM32F303C8 and STM32F303K8 when connected through the ULINK2 JTAG debugger.
I have tried deleting the dbgconf file as suggested in this page: http://www.keil.com/support/docs/4057.htm. I also tried fully uninstalling Keil uVision5 from my laptop (running Windows 10 64-bit) and deleting the registries in Registry Editor along with Keil folders/files under <users>/AppData/Local/Arm and C:/Keil_v5, and reinstalling everything and the error still persists.
Are there any workarounds to this error? Why did the error appear even though Keil was behaving normally previously? Any help would be greatly appreciated.
Thank you!
I'have the same problem using:
uvision V5.31.0.0
STM32L471Gtx
ULINK2
I tried https://www.keil.com/support/docs/4098.htm or http://www.keil.com/support/docs/4057.htm ( both describe the same solution) but the problem persist. Have someone resolved this issue?
I resolved my issue by changing the Connect and Reset options (found in Options for Target --> Debug tab --> Settings --> (under Debug tab in the bottom pane that also shows Debug):
Under the Flash Download tab (right beside the Debug tab and Trace tab), I also selected 'Erase Full Chip' under Download Function.
I got the solution from a Support Engineer. Apparently, some ST devices are very particular/picky about the Connect and Reset options.
