Hi All,
I'm using Keil5 developing application on a Cortex-M0 platform with FreeRTOS example.
In FreeRTOS, there is a global buffer ucHeap[] doing the memory dynamic allocation and free, it also used as the heap for OS tasks stack.
I want to define the size of ucHeap as bigger as it can, until use up the whole SRAM memory.
So I want to realize a function in Keil5 to change the size of ucHeap everything time based on other RW/ZI usage.
For example,
i)The total SRAM is 20KB, other RW/ZI/STACK usage is already 10KB, the Keil5 can allocate 20-10=10KB for the ucHeap.
ii)The total SRAM is 20KB, other RW/ZI/STACK usage is already 8KB, the Keil5 can allocate 20-8=12KB for the ucHeap.
Currently I manually change the size of ucHeap everytime to use up the whole SRAM. I would like to have method to achieve this function automatically.
Thanks.
Best Regards.
Have you asked on the FreeRTOS forums - if anyone there has already done this?
These may help:
https://developer.arm.com/documentation/dui0474/f/accessing-and-managing-symbols-with-armlink/region-related-symbols?lang=en
Andy Neil said:Have you asked on the FreeRTOS forums
The answer is here https://forums.freertos.org/t/squeeze-all-sram-memory-into-freertos-heap-in-keil5/10200/9
