I am trying to receive debug messages to UART1 in Keil 4
This peace of code successfully works with Generic 8051 device and internal simulator.
But when I open real device (EX-F34x-Q-48) debug has stopped on checking interrupt bit.
For real device I have put another "h" file - c8051F340.h
What I am wrong?
//-----Fosc = 11.592MHz, Baud Rate = 9600-------// #include<reg51.h> void uart_init(); void timer_init(); void uart_tx(unsigned char x); unsigned char uart_rx(); void uart_msg(unsigned char *c); void n_line(); void delay(unsigned int ms); unsigned char tx_data; void main() { uart_init(); uart_msg("Initializzing Serial Communication"); n_line(); delay(10); uart_msg("Processing....."); delay(1000); n_line(); uart_msg("Connected"); n_line(); while(1) { uart_msg("<<"); tx_data = uart_rx(); n_line(); n_line(); uart_msg(">>"); uart_tx(tx_data); n_line(); n_line(); } } void uart_init() { SCON = 0x50; timer_init(); } void timer_init() { TMOD = 0x20; TH1 = 0xFD; TR1 = 1; } void uart_tx(unsigned char x) { SBUF = x; while(!TI); TI = 0; } unsigned char uart_rx() { unsigned char z; while(!RI); z = SBUF; RI = 0; return(z); } void uart_msg(unsigned char *c) { while(*c != 0) { uart_tx(*c++); } } void delay(unsigned int ms) { int i,j; for(i=0;i<=ms;i++) for(j=0;j<=120;j++); } void n_line() { uart_tx(0x0d); }
TI0 in header file has another value...
