I am not sure how to fully explain this issue, so please let me know what further information I should provide. I am trying to program my EK-TM4C123GXL board however after uploading some (probably faulty) code, Keil crashes after starting the debug session. If it helps, I was trying to set up Port D for interrupts. Also, I can no longer run simulations either. When I do, Keil says I have memory access violations. The strangest part is this issue now occurs when I try to upload previous working programs as well.
re: "Memory Access Violations" - the simulator is a bit of a sandbox, giving greater control over debugging a device.
- On real hardware, if a program tries to access memory that doesn't exist, it just tries and may crash.
- With simulator debugging, under debug -> memory map, this window shows what areas the program can access and how - this is great for catching bad pointers, runaway indexes etc.
http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_memmap.htm
http://www.keil.com/support/man/docs/uv4/uv4_dg_memmap.htm
Sounds like your memory map is incomplete. You could:
1) Use the Memory Map dialog to map ranges in.
2) Or use the MAP debug command in the command window or in a initialization filewww.keil.com/.../814.htmwww.keil.com/.../uv4_cm_map.htm
re: the TM4C123GXL board. Try one of the examples from the CMSIS-Packs, to make sure the board works with a known working example
Read more about the examples at: https://www.keil.com/dd2/texasinstruments/tm4c123gh6pm/
