I use a simple delay clock code. But whenever I use this code program won't start without entering debug mode in KEIL. I plug stlink out and reconnect but it wont work if I don't enter the debug mode. Is there any solution to this. If not then what else can I use to have 100 us delay. Thank you for reading
uint32_t startTick = DWT->CYCCNT, delayTicks = 100 * (SystemCoreClock/1000000); while (DWT->CYCCNT - startTick < delayTicks);
You need to enable the functional blocks involved, the debugger does this for itself.
CoreDebug->DEMCR |= 0x01000000; // TRCENA DWT->LAR = 0xC5ACCE55; // unlock on CM7 cores DWT->CYCCNT = 0; // reset the counter DWT->CTRL |= 1 ; // enable the counter
The alternative obviously would be to create a different free-running TIM, perhaps clocking at 1 MHz (1us) and use that to mark time via TIMx->CNT, where TIMx->ARR is maximal, ie 0xFFFF or 0xFFFFFFFF for 16-bit and 32-bit respectively.
Thanks a lot for your answer. There is an error with LAR, it is not a member of DWT. But I deleted this line. It worked :)
Ok thanks. I will also try this method.
Depends on the model of Cortex-M, which you didn't specify. With the CM7 it must be unlocked
From ...\CMSIS\Include\core_cm7.h
/** \ingroup CMSIS_core_register \defgroup CMSIS_DWT Data Watchpoint and Trace (DWT) \brief Type definitions for the Data Watchpoint and Trace (DWT) @{ */ /** \brief Structure type to access the Data Watchpoint and Trace Register (DWT). */ typedef struct { __IOM uint32_t CTRL; /*!< Offset: 0x000 (R/W) Control Register */ __IOM uint32_t CYCCNT; /*!< Offset: 0x004 (R/W) Cycle Count Register */ __IOM uint32_t CPICNT; /*!< Offset: 0x008 (R/W) CPI Count Register */ __IOM uint32_t EXCCNT; /*!< Offset: 0x00C (R/W) Exception Overhead Count Register */ __IOM uint32_t SLEEPCNT; /*!< Offset: 0x010 (R/W) Sleep Count Register */ __IOM uint32_t LSUCNT; /*!< Offset: 0x014 (R/W) LSU Count Register */ __IOM uint32_t FOLDCNT; /*!< Offset: 0x018 (R/W) Folded-instruction Count Register */ __IM uint32_t PCSR; /*!< Offset: 0x01C (R/ ) Program Counter Sample Register */ __IOM uint32_t COMP0; /*!< Offset: 0x020 (R/W) Comparator Register 0 */ __IOM uint32_t MASK0; /*!< Offset: 0x024 (R/W) Mask Register 0 */ __IOM uint32_t FUNCTION0; /*!< Offset: 0x028 (R/W) Function Register 0 */ uint32_t RESERVED0[1U]; __IOM uint32_t COMP1; /*!< Offset: 0x030 (R/W) Comparator Register 1 */ __IOM uint32_t MASK1; /*!< Offset: 0x034 (R/W) Mask Register 1 */ __IOM uint32_t FUNCTION1; /*!< Offset: 0x038 (R/W) Function Register 1 */ uint32_t RESERVED1[1U]; __IOM uint32_t COMP2; /*!< Offset: 0x040 (R/W) Comparator Register 2 */ __IOM uint32_t MASK2; /*!< Offset: 0x044 (R/W) Mask Register 2 */ __IOM uint32_t FUNCTION2; /*!< Offset: 0x048 (R/W) Function Register 2 */ uint32_t RESERVED2[1U]; __IOM uint32_t COMP3; /*!< Offset: 0x050 (R/W) Comparator Register 3 */ __IOM uint32_t MASK3; /*!< Offset: 0x054 (R/W) Mask Register 3 */ __IOM uint32_t FUNCTION3; /*!< Offset: 0x058 (R/W) Function Register 3 */ uint32_t RESERVED3[981U]; __OM uint32_t LAR; /*!< Offset: 0xFB0 ( W) Lock Access Register */ __IM uint32_t LSR; /*!< Offset: 0xFB4 (R ) Lock Status Register */ } DWT_Type;
