I have several nodes that are running the same project/code. I need to debug them simultaneously and that requires having separate workspaces. Now I have multiple copies of the same project. Yes, they do share the same sources but I also want to have the same project settings.
Thanks.
Hello Bar,
Wanted to make sure you knew about these:
http://www.keil.com/support/docs/4096.htm
http://www.keil.com/support/man/docs/uv4/uv4_ca_createmultiprojectfile.htm
you could create separate multi project work spaces, and each project could have different targets, target a, and target b
I'm not sure that my question was correctly stated. I have multiple copied of exactly the same project. No problem to compile nor build it but as soon as I need to debug a couple of identical boards running exactly the same code simultaneously(they are talking to each other) I have issues with the debugger - they are influencing with each other. To solve that I'm copying one project into several and any single change in the project settings(not files) has to be repeated in every single copy. My guess that if I could have a single .uvprojx file and multiple uvguix then it would solve my issue as well.
