I am using KEIL floating license and I tried to launch debug session my project. I can build the project and load it into development kit.
However, The following error message appears when I start debug session. I would be really appreciated if you can help me to solve this problem.
Best regards.
Error Message
Build Time Elapsed: 00:00:42Load "proj.axf" Erase Done.Programming Done.Verify OK.Flash Load finished at 13:57:03Error: *** License Mapping Failed! ***
Debugger aborted !Incorrect license ID code (LIC) in 'TOOLS.INI'
What version of the Keil tools are you using?
Did you update recently?
Were you previously using an evaluation version of the tools?
