I am using KEIL floating license and I tried to launch debug session my project. I can build the project and load it into development kit.
However, The following error message appears when I start debug session. I would be really appreciated if you can help me to solve this problem.
Best regards.
Error Message
Build Time Elapsed: 00:00:42Load "proj.axf" Erase Done.Programming Done.Verify OK.Flash Load finished at 13:57:03Error: *** License Mapping Failed! ***
Debugger aborted !Incorrect license ID code (LIC) in 'TOOLS.INI'
As you have a licence, you should contact Keil support direct.
