How to get the source codes of DFP, CMSIS etc. into Keil directory.My packs are 'Up to date', but PACK folder ist empty.
Another user posted a similar issue recently (packs installing, but devices not available for use) and needed to reinstall uVision to get back on track. Can you make projects using the packs you downloaded?
Your screenshot doesn't show the path that the pack installer tool is using as its root directory -- the path is shown in the title bar and the packs should be underneath that folder. You could try a search for the downloaded packs (*.pack) and their description files (*.pdsc). Is it possible that you have (or had) MDK installed in another path?
Thank you for this hint. Yes, pack path is under /Users/...Can copy files from this path \Arm to Keil MDK installation path.How to get Pack Installer to further use the path under Keil MDK Installation path ?Thank you for your support.
Have found it searching for path infiles. Found TOOLS.INI and therein RTEPATH.
