As far as the memory window goes, you can change the data format by right clicking, and clicking Decimal. This should take global effect.
Also, you could look at using the Logic Analyzer http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_logicanalyzer.htm
You could also look at using DMA to store values to RAM and dump it later.
