Linker issues on ARMv6-M
Hello team,
I am working on NXP's S32K116 micro (Core - M0+). CPU for this is ARMv6-M. Also I am using IAR compiler.
I am having linker issues when I try to call functions from interrupt handlers defined in the Startup_S32K116.s file
Below are some of the handlers where I am calling functions:
EXTERN vPortSVCHandler
EXTERN xPortPendSVHandler
EXTERN xPortSysTickHandler
EXTERN UnusedIntVctrIRQHandler
PUBWEAK SVC_Handler
SECTION .text:CODE:REORDER:NOROOT(1)
SVC_Handler
B vPortSVCHandler
PUBWEAK PendSV_Handler
PendSV_Handler
B xPortPendSVHandler
PUBWEAK SysTick_Handler
SysTick_Handler
B xPortSysTickHandler
PUBWEAK DefaultISR
DefaultISR
B UnusedIntVctrIRQHandler
But I am getting following linker error when I compile the software. Actually it is reporting same issues with all the functions above with different values.
Error[Lp002]: relocation failed: value out of range or illegal: 0x707e
Kind : R_ARM_THM_JUMP11[0x66]
Module: C:\Workspace\GM\PWS\Git_Sandboxes\T6906-86_Smart_FET_Dr
iver\40_implementation\10_Software_Dev\20_ProductionCode\Build\Startu
p\startup_S32K116.o
Section: 15 (.text)
Offset: 0x0
Target : 0x9e95
"UnusedIntVctrIRQHandler"
iver\40_implementation\10_Software_Dev\20_ProductionCode\Build\Servic
es\MCUFaultHandler\UnusedIntVectorHandler.o
Section: 9 (.text)
Offset: 0x1
NOTE: The same function calls I have made from the startup file Interrupt handlers of Core M4 project startup file. CPU for this is ARMv7-M. There I did not see any Linker issues. Please suggest.
  • ARMv6-M is the architecture, not the CPU. Your CPU is a Cortex-M0+, which uses the Thumb/Thumb2 instruction set. The Thumb instruction set uses fewer bits to encode instructions, which limits how far away the target of a branch can be. The error is telling you that the value needed for the branch doesn't fit into the instruction and your linker is unable to solve the problem on its own. One way to solve this is to put the address into register r0, then branch to the address in the register, like this:
       IMPORT  UnusedIntVctrIRQHandler
       LDR     r0, =UnusedIntVctrIRQHandler
       BX      r0
       BX      r0
