Keil uVision 5 under VMWare Fusion - can't set breakpoints!
For the past couple months, I have been running Keil uVision 5 within Windows 10 hosted in Mac OS Mojave. I have not encountered any issues until just now. But I've just discovered a weirdness with this particular project, and I'm not sure what could be causing it. I made a video that I'll link to below.
I can launch and run this project in the debugger and set a breakpoint in main() if the project files are located on the windows desktop. Note the black bars to the left of main, indicating where breakpoints can be set, and the red dot is a breakpoint that has been set. All good. So I close this window, and copy the entire project folder to a folder that happens to be a VMWare share (folder hosted on MacOS and shared to Windows via VMWare), I can open the project here.
But note that even after rebuilding everything, the grey bars are gone, the red dot is replaced by a question mark, indicating I cannot set breakpoints anywhere. And apparently the linker doesn't even recognize main(). If I step through startup in the debugger, the call to __main does not jump to main() in main.c. Very odd.
Any suggestions (other than the obvious, run the project from the Windows desktop). I would like to be able to have the project files located on a VMWare share for a number or reasons.
Screen shot video here:  www.youtube.com/watch
