I use last version of ST CubeMX on generate project for STM32F103C8 and I want to add MDK-Middleware component for example emWin.
Because MDK-Middleware only includes emwin support with RTOS, I in CubeMX generate very simple project, only add FreeRTOS and activate I2C1 for I2C OLED with SSD1306 driver and generate project for MDK-ARM v>5.27.
Generated projet is in MDK-ARM v5.3 compiled OK.
Now I use manager Run Time Enviromet for add Grphics core (emWin v6.10.8) and uSe button Resolve for solve dependencies. This Add CMSIS CORE, RTOS2 KeilRTX5, Device Srartup and Display Interface Temolates
The compulatiuon attempt ends in error XXX.sct(7): error: L6235E: More than one section matches selector - cannot all be FIRST/LAST.
becouse CumeMX insert ApplicationMDK-ARM/startup_STM32F103xb.s and MDK-ARM insert Device/startup_stm32f10x_md.s and both contain AREA RESET, DATA, READONLY.
How to correctly add components from MDK-Middleware to a project from CubeMX?
Respectively, I solve this problem?
