Build started: Project: first*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'Build target 'Target 1'assembling Startup.s...Startup.s: Error: A9580E: ARM7 is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Startup.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:Startup.s: www.keil.com/.../license_management.htmStartup.s: If you need further help, provide this complete error report to your supplier or license.support@arm.com.Startup.s: - ARMLMD_LICENSE_FILE: unsetStartup.s: - LM_LICENSE_FILE: unsetStartup.s: - ARM_TOOL_VARIANT: unsetStartup.s: - ARM_PRODUCT_PATH: unsetStartup.s: - Product location: C:\Keil_v5\ARM\sw\mappingsStartup.s: - Toolchain location: C:\Keil_v5\ARM\ARMCC\BinStartup.s: - Selected tool variant: mdk_liteStartup.s: Product: MDK-ARM Lite 5.30Startup.s: Component: ARM Compiler 5.06 update 6 (build 750)Startup.s: Tool: ArmAsm [4d35ec]Startup.s: error: A3903U: Argument 'ARM7TDMI' not permitted for option 'cpu'.compiling led3.C...Error: C9580E: ARM7 is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: www.keil.com/.../license_management.htm If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Keil_v5\ARM\sw\mappings - Toolchain location: C:\Keil_v5\ARM\ARMCC\Bin - Selected tool variant: mdk_liteProduct: MDK-ARM Lite 5.30Component: ARM Compiler 5.06 update 6 (build 750)Tool: ArmCC [4d3637]Fatal error: C3903U: Argument 'ARM7TDMI' not permitted for option 'cpu'.".\Objects\first.axf" - 4 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:01
I installed software and did one program but this error is showing to me how to tackle it.
The current limitations of the 5.30 lite/evaluation version seems to exclude support for ARM7.
https://www2.keil.com/limits
http://www2.keil.com/mdk5/selector
I personally do not know how to get a Keil MDK evaluation version for the ARM7.
Your links provided already confirm the status on a Support, but let me again summarize:
- According to the summary of MDK Editions support for Arm7/9/R4 series requires a valid registration of MDKpro or MDKplus, see i.e.:
- In addition it is required to install the corresponding Legacy Pack offered at:
http://www2.keil.com/mdk5/legacy/
