Compilation fault using Keil uVision
Hello all!
I'm writing to a chip with a cortex m-4  in it and the compiler creates a weird assembly:
I'm trying to develop an I2C driver so i have a made some unions to allow easy access to registers, it all worked fine until today - today things got quite phishy!
take a look:
compiler option:
here is the code for the union of "reg":
typedef union
    uint32_t value;
    struct
        unsigned dummy1 :1
        unsigned dummy2 :1
        unsigned dummy32 :1
    }fields;
} IC_INTR_MASK;
//module typedef
typedef struct _MODULE_S
    IC_INTR_STAT IC_INTR_STAT;
} I2CInitDef;
As you can see the compiler creates the assembly with a "!"(write back to the register) - so after I write 0x00 to "reg->IC_INTR_MASK.value" the pointer of "reg" is no longer point to the right address!
I can tell I'm using this method to write hardware registers all over my code and it always works fine! what do you thing might be the problem here?
