Ok, this can't be this hard! Please show me the error of my ways.
I am using Keil uVision, building for LPX40xx processors, and I want to crank the warning levels up (more strict). I'm used to using --pedantic with gcc and would like to be able to enable the same sort of syntax checking in my Keil project.
I see where I can add command line armcc options under "Misc Controls" within the "Options For Target / C/C+" tab, so based on this:
https://developer.arm.com/docs/100748/latest/using-common-compiler-options/controlling-diagnostic-messages
I've tried adding -Wpedantic, and I get: Fatal error: C3900U: Unrecognized option '-pedantic'.
I would also be fine with doing this on a file-by-file basis, by adding #pragma diag_warning statements to my source files, as hinted at here:
infocenter.arm.com/.../index.jsp
but I can't find a list of tags.
Any help would be gratefully appreciated.
--strict seems very close to the gnu --pedantic.
Thanks Robert. --strict appears to not be the correct syntax. I tried this, and everything blows up, including the Keil-supplied files:
compiling I2C_LPC40xx.c..."no source": Error: command-line: #1055: language modes specified are incompatibleC:\Users\dtc46\AppData\Local\Arm\Packs\Keil\LPC4000_DFP\2.1.0\RTE_Driver\I2C_LPC40xx.c: 0 warnings, 1 error
