FLM and Keil version
Hi all,
One question regarding including a custom FLM file in the Flash Download dialog.
Does the Keil version used to compile the FLM in the first place has any implication on whether or not the FLM can be used in other Keil versions?
I compiled an initial FLM with an older full version of Keil and found out that I could not include it in the current Keil Lite. It gets selected in the window but then doesn't stay in the window ie. can't be added to the programming algorithm.
However, recompiling it with a current Eval version of Keil and then using it in a current Keil Lite was ok and working.
Has anyone faced something like that before?
Thanks in advance.
