Hello.
I'd like to activate the Debug viewer for Cortex-M0. (STM32f030R8)I follow the instruction. (I attached the instruction file that I did.)but it did not work.
The full code is also attached.
Please review all things and let me know what i should do.Thank you very much for reading.
Sincerely,Daseseong YuUART_Temp.zipn.1462.M0_EVR.pdf
Nothing really leaps out as a reason why it wouldn't work for you. I tried this with a Microchip SAMC21N using CMSIS-DAP (I don't have any ST boards). My test was a little more minimal than yours. I got output in the debug window and in the event recorder window, although it took a few seconds to show up after running from main. Is it possible that something in your HAL_init() is causing EVR to not work? Can you generate any other EVR messages?
#include "stdio.h" #include "EventRecorder.h" int main(void) { EventRecorderInitialize(EventRecordAll, 1); printf("Hello, world!\n"); for (;;) { ; // Do nothing. } return 0; }
https://www.keil.com/pack/doc/compiler/RetargetIO/html/_retarget__examples_er.html
Thank you very much for your answer sincerely.
I appreciate your answer really.
Thank you again.
