when i try to debug in simulator mode in the keil this error is occurred.
Error: Could not load file 'C:\Keil_v5\ARM\Project\Objects\add.axf'. Debugger aborted !
what should i do?
please help me.......
1.) Press windows+R button2.)Type "regedit"3.)Go this directory "HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers"4.)If is there UV4.exe or UV5.exe than delete it. (Your keil must be closed before delete.) Than you can debug
