after writng
void main(void)
.....curly bracket symbol here need which key on key board should i press or drag symbol from somewhere.
I am wondering if you do not know how the curly bracket symbol looks like or you posted here because you think Keil manufactures keyboards ?
https://lmgtfy.com/?q=curly+bracket+symbol&s=l&qtype=search&ovr=1
hardeep India said:which key on key board should i press
Err ... the ones which have the curly brackets printed on them ?!
https://www.computerhope.com/jargon/c/curlybra.htm
EDIT
Of course, none of this has anything specifically to do with Keil or ARM - or even with programming!
The keys are exactly the same whatever application you use - whether it's uVision, or another IDE, or another editor, or a word processor, or a spreadsheet, or the command line, or ...
thanks a lot, the kitty is under the chair i am looking around the town.....thanks alot
hardeep India said:the kitty is under the chair i am looking around the town
Is the lockdown getting to you?
sure i am trying to take advantage of lockdown,,lockdown took advantage of me..lol
