I have a project where I can compile and debug as long as the optimization level is set at Oz (image size) but when I attempt to debug after compiling with no optimization O0 the application will not run.
groupalpha said:the application will not run
What, exactly, do you mean by that?
Probably below link should help:http://www.keil.com/support/docs/3614.htm
groupalpha said:the application will not run.
Telling people one of the infinitely many things that do not happen is very rarely of use to anyone. What you should check (and then tell the world about) is what does happen, and why that's not what you believe should have happened.
Perhaps the build doesn't complete because the image is too large for the evaluation version of the compiler?
At least attach the build log for the project so people can figure out wth is going on
