I am new to embedded software development but I have chosen to begin learning through the KL25Z board. At the moment, I am exploring the use of SysTick interrupts, but after debugging and reducing my code, I see that it never enters the SysTick ISR. I am confused as to how I should proceed from here. If there is an external linkage to the SysTick_Handler() that I need to include, I'm not sure how to do it, or how to trace it down.
Here is my code:
#include "MKL25Z4.h" /* GLOBAL VARIABLES */ /* FUNCTION PROTOTYPES */ /* MAIN PROGRAM */ int main (void) { SIM->SCGC5 |= 0x0400; /* enable clock to Port B */ PORTB->PCR[18] = 0x100; /* make PTB18 pin as GPIO */ PTB->PDDR |= 0x040000; /* make PTB18 as output pin */ SysTick->LOAD = 8388000 - 1; /* reload with number of clocks per 200 ms */ SysTick->CTRL = 5; /* enable it, no interrupt, use system clock */ while (1) { } } /* LED INITIALIZATION */ void SysTick_Handler() { PTB->PTOR = 0x040000; /* toggle red LED */ }
If I put the following into the while loop, the code works as expected (i.e. red on-board LED toggled):
if (SysTick->CTRL & 0x10000) /* if COUNT flag is set */ PTB->PTOR = 0x040000; /* toggle red LED */
These are the RTE packs I have included in Keil uVision5:
Board Support > LED (API) > LED driver for NXP FRDM-KL25Z board
CMSIS > CMSIS-CORE for Cortex-M, SC000, SC300, ARMv8-M, ARMv8.1-M
CMSIS > CMSIS-DSP Library for Cortex-M, SC000, and SC300
CMSIS > CMSIS-NN Neural Network Library
Compiler > Event Recording and Component Viewer via Debug Access Port (DAP)
Device > System Startup for NXP MKL25Z4 Devices
Any pointers that you could give me would be greatly appreciated.
Thank you.
Wait! SysTick->CTRL should be 0x07.
perhaps it would be clearer if you used symbolic bit names rather than just a "Magic Number" ?
Agreed. I look at the datasheet and then don't define macros, or end up not using the ones in the MKL25Z4.h library. It ends up muddying things for me when debugging.
