Background
On our company, we precompile our platform library into a .lib and provide these library to other developers.Till the day, we've used the default startup provided in the Standard Peripheral Library from ST.
Goal
We need to allow the user to customize the Stack and Heap Size.What we have tried
For this example we're using and STM32F103RB(Nucleo Board).
I've tried to split the startup we've been using in two; one will carry the Heap and Stack definitions and the other will be contain the vector definitions.The file with the vectors definitions(stm32f1_md_vectors.s) will be included in the .lib file and the other will be linked by the Application developer and together with hiw own code and the .lib file.These are the milestones I propose:
0) Compile the .lib and link it to an application to obtain the map.
1) Split the startup file in two
2) Assemble them and ensure they work together in the same way than the single startup
3) Assemble them and incorporate them into the .lib and ensure it works like point 2)
4) Assemble the vector stm32f1_md_vectors.s and incorporate in the .lib. Assemble the startup.s and link with the application and the .lib This is the code I'm using:Code of the startup.s:
; Amount of memory (in bytes) allocated for Stack ; Tailor this value to your application needs ; <h> Stack Configuration ; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; <h> Heap Configuration ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB ;******************************************************************************* ; User Stack and Heap initialization ;******************************************************************************* IF :DEF:__MICROLIB EXPORT __initial_sp EXPORT __heap_base EXPORT __heap_limit ELSE IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN ENDIF END
; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY IMPORT __initial_sp EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1 DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2 DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3 DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4 DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5 DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6 DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7 DCD ADC1_IRQHandler ; ADC1 DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD EXTI9_5_IRQHandler ; EXTI Line 9..5 DCD TIM1_BRK_TIM15_IRQHandler ; TIM1 Break and TIM15 DCD TIM1_UP_TIM16_IRQHandler ; TIM1 Update and TIM16 DCD TIM1_TRG_COM_TIM17_IRQHandler ; TIM1 Trigger and Commutation and TIM17 DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; EXTI Line 15..10 DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line DCD CEC_IRQHandler ; HDMI-CEC DCD TIM12_IRQHandler ; TIM12 DCD TIM13_IRQHandler ; TIM13 DCD TIM14_IRQHandler ; TIM14 DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_DAC_IRQHandler ; TIM6 and DAC underrun DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1 DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2 DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3 DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5 DCD DMA2_Channel5_IRQHandler ; DMA2 Channel5 __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors AREA |.text|, CODE, READONLY ; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Dummy Exception Handlers (infinite loops which can be modified) NMI_Handler PROC EXPORT NMI_Handler [WEAK] B . ENDP HardFault_Handler\ PROC EXPORT HardFault_Handler [WEAK] B . ENDP MemManage_Handler\ PROC EXPORT MemManage_Handler [WEAK] B . ENDP BusFault_Handler\ PROC EXPORT BusFault_Handler [WEAK] B . ENDP UsageFault_Handler\ PROC EXPORT UsageFault_Handler [WEAK] B . ENDP SVC_Handler PROC EXPORT SVC_Handler [WEAK] B . ENDP DebugMon_Handler\ PROC EXPORT DebugMon_Handler [WEAK] B . ENDP PendSV_Handler PROC EXPORT PendSV_Handler [WEAK] B . ENDP SysTick_Handler PROC EXPORT SysTick_Handler [WEAK] B . ENDP Default_Handler PROC EXPORT WWDG_IRQHandler [WEAK] EXPORT PVD_IRQHandler [WEAK] EXPORT TAMPER_IRQHandler [WEAK] EXPORT RTC_IRQHandler [WEAK] EXPORT FLASH_IRQHandler [WEAK] EXPORT RCC_IRQHandler [WEAK] EXPORT EXTI0_IRQHandler [WEAK] EXPORT EXTI1_IRQHandler [WEAK] EXPORT EXTI2_IRQHandler [WEAK] EXPORT EXTI3_IRQHandler [WEAK] EXPORT EXTI4_IRQHandler [WEAK] EXPORT DMA1_Channel1_IRQHandler [WEAK] EXPORT DMA1_Channel2_IRQHandler [WEAK] EXPORT DMA1_Channel3_IRQHandler [WEAK] EXPORT DMA1_Channel4_IRQHandler [WEAK] EXPORT DMA1_Channel5_IRQHandler [WEAK] EXPORT DMA1_Channel6_IRQHandler [WEAK] EXPORT DMA1_Channel7_IRQHandler [WEAK] EXPORT ADC1_IRQHandler [WEAK] EXPORT EXTI9_5_IRQHandler [WEAK] EXPORT TIM1_BRK_TIM15_IRQHandler [WEAK] EXPORT TIM1_UP_TIM16_IRQHandler [WEAK] EXPORT TIM1_TRG_COM_TIM17_IRQHandler [WEAK] EXPORT TIM1_CC_IRQHandler [WEAK] EXPORT TIM2_IRQHandler [WEAK] EXPORT TIM3_IRQHandler [WEAK] EXPORT TIM4_IRQHandler [WEAK] EXPORT I2C1_EV_IRQHandler [WEAK] EXPORT I2C1_ER_IRQHandler [WEAK] EXPORT I2C2_EV_IRQHandler [WEAK] EXPORT I2C2_ER_IRQHandler [WEAK] EXPORT SPI1_IRQHandler [WEAK] EXPORT SPI2_IRQHandler [WEAK] EXPORT USART1_IRQHandler [WEAK] EXPORT USART2_IRQHandler [WEAK] EXPORT USART3_IRQHandler [WEAK] EXPORT EXTI15_10_IRQHandler [WEAK] EXPORT RTCAlarm_IRQHandler [WEAK] EXPORT CEC_IRQHandler [WEAK] EXPORT TIM12_IRQHandler [WEAK] EXPORT TIM13_IRQHandler [WEAK] EXPORT TIM14_IRQHandler [WEAK] EXPORT TIM5_IRQHandler [WEAK] EXPORT SPI3_IRQHandler [WEAK] EXPORT UART4_IRQHandler [WEAK] EXPORT UART5_IRQHandler [WEAK] EXPORT TIM6_DAC_IRQHandler [WEAK] EXPORT TIM7_IRQHandler [WEAK] EXPORT DMA2_Channel1_IRQHandler [WEAK] EXPORT DMA2_Channel2_IRQHandler [WEAK] EXPORT DMA2_Channel3_IRQHandler [WEAK] EXPORT DMA2_Channel4_5_IRQHandler [WEAK] EXPORT DMA2_Channel5_IRQHandler [WEAK] WWDG_IRQHandler PVD_IRQHandler TAMPER_IRQHandler RTC_IRQHandler FLASH_IRQHandler RCC_IRQHandler EXTI0_IRQHandler EXTI1_IRQHandler EXTI2_IRQHandler EXTI3_IRQHandler EXTI4_IRQHandler DMA1_Channel1_IRQHandler DMA1_Channel2_IRQHandler DMA1_Channel3_IRQHandler DMA1_Channel4_IRQHandler DMA1_Channel5_IRQHandler DMA1_Channel6_IRQHandler DMA1_Channel7_IRQHandler ADC1_IRQHandler EXTI9_5_IRQHandler TIM1_BRK_TIM15_IRQHandler TIM1_UP_TIM16_IRQHandler TIM1_TRG_COM_TIM17_IRQHandler TIM1_CC_IRQHandler TIM2_IRQHandler TIM3_IRQHandler TIM4_IRQHandler I2C1_EV_IRQHandler I2C1_ER_IRQHandler I2C2_EV_IRQHandler I2C2_ER_IRQHandler SPI1_IRQHandler SPI2_IRQHandler USART1_IRQHandler USART2_IRQHandler USART3_IRQHandler EXTI15_10_IRQHandler RTCAlarm_IRQHandler CEC_IRQHandler TIM12_IRQHandler TIM13_IRQHandler TIM14_IRQHandler TIM5_IRQHandler SPI3_IRQHandler UART4_IRQHandler UART5_IRQHandler TIM6_DAC_IRQHandler TIM7_IRQHandler DMA2_Channel1_IRQHandler DMA2_Channel2_IRQHandler DMA2_Channel3_IRQHandler DMA2_Channel4_5_IRQHandler DMA2_Channel5_IRQHandler B . ENDP ALIGN END
LR_IROMPROGRAM1 0x08000000 0x1C800 { ; load region size_region ER_IROM1 0x08000000 0x1C800 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20000000 0x00010000 { ; RW data .ANY (+RW +ZI) } } LR_IROMDATA1 0x0801F800 0x800 { ; load region size_region ER_EMPTY1 0x0801F800 EMPTY 0x800 { ;Empty region not zero-initialized in run time } }
Outcome2) It works when I compile the files together in a sample project.
3) It succeds in incorporating them in the.lib , but when I try to link them with the application, it seems the RESET area isn't found. This is the linker output:"..\..\.\output\generated\gf_hal.sct", line 10 (column 9): Error: L6236E: No section matches selector - no section to be FIRST/LAST.Not enough information to list image symbols.Not enough information to list the image map.Finished: 2 information, 0 warning and 1 error messages.Error: Linker error 1I attach three maps: the one obtained in the steps 0, 2 and 3.
Tomorrow I'll try to reproduce the steps 2 and 3 with a minimal library(and no propetary code) so I can provide sample projects.
MapFiles.zip
dBeltran said:I've tried to split the startup we've been using in two; one will carry the Heap and Stack definitions and the other will be contain the vector definitions.
That most likely won't work. Libraries are a pull service: the linker can pull from them what it needs. But it won't know that it needs to pull the in-library part of your start-up, because it sees no particular reason to do that.
The start-up file is not just the file the microcontroller code starts from. In a library-based build it's also the file the linker starts its discovery of things needed to complete the program from. Start-up pulls in the run-time library by requiring things from it, that pulls in the file with main() in it by trying to call main(), and that pulls the whole program along with it.
Because of that, start-up files are singularly ill-fitted for inclusion in libraries.
Do you have any proprietary code in the startup file? If not, let the user supply
Consider also if you can just import the size values.
I can just import the values, but how could I do this in a separate file? Is it possible to export EQU's? Variables aren't defined till __main is called, so I can't use variables to store the size values.
I agree is ill-fitted, but at the moment I haven't tried to separate the modules in the toolchain. I'm just trying to assemble them and incorporate them in the .lib with the same behaviour of the original start-up.
I've realized in the startup file I created I didn't set the proper AREA for the User Stack and Heap initialization (.text). So I changed the files, and added the export's/ import's that were missing. These are the new files:Code of the stm32f1_md_vectors.s file:; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY IMPORT __initial_sp EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1 DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2 DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3 DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4 DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5 DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6 DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7 DCD ADC1_IRQHandler ; ADC1 DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD EXTI9_5_IRQHandler ; EXTI Line 9..5 DCD TIM1_BRK_TIM15_IRQHandler ; TIM1 Break and TIM15 DCD TIM1_UP_TIM16_IRQHandler ; TIM1 Update and TIM16 DCD TIM1_TRG_COM_TIM17_IRQHandler ; TIM1 Trigger and Commutation and TIM17 DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; EXTI Line 15..10 DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line DCD CEC_IRQHandler ; HDMI-CEC DCD TIM12_IRQHandler ; TIM12 DCD TIM13_IRQHandler ; TIM13 DCD TIM14_IRQHandler ; TIM14 DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_DAC_IRQHandler ; TIM6 and DAC underrun DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1 DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2 DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3 DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5 DCD DMA2_Channel5_IRQHandler ; DMA2 Channel5 __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors AREA |.text|, CODE, READONLY ; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Dummy Exception Handlers (infinite loops which can be modified) NMI_Handler PROC EXPORT NMI_Handler [WEAK] B . ENDP HardFault_Handler\ PROC EXPORT HardFault_Handler [WEAK] B . ENDP MemManage_Handler\ PROC EXPORT MemManage_Handler [WEAK] B . ENDP BusFault_Handler\ PROC EXPORT BusFault_Handler [WEAK] B . ENDP UsageFault_Handler\ PROC EXPORT UsageFault_Handler [WEAK] B . ENDP SVC_Handler PROC EXPORT SVC_Handler [WEAK] B . ENDP DebugMon_Handler\ PROC EXPORT DebugMon_Handler [WEAK] B . ENDP PendSV_Handler PROC EXPORT PendSV_Handler [WEAK] B . ENDP SysTick_Handler PROC EXPORT SysTick_Handler [WEAK] B . ENDP Default_Handler PROC EXPORT WWDG_IRQHandler [WEAK] EXPORT PVD_IRQHandler [WEAK] EXPORT TAMPER_IRQHandler [WEAK] EXPORT RTC_IRQHandler [WEAK] EXPORT FLASH_IRQHandler [WEAK] EXPORT RCC_IRQHandler [WEAK] EXPORT EXTI0_IRQHandler [WEAK] EXPORT EXTI1_IRQHandler [WEAK] EXPORT EXTI2_IRQHandler [WEAK] EXPORT EXTI3_IRQHandler [WEAK] EXPORT EXTI4_IRQHandler [WEAK] EXPORT DMA1_Channel1_IRQHandler [WEAK] EXPORT DMA1_Channel2_IRQHandler [WEAK] EXPORT DMA1_Channel3_IRQHandler [WEAK] EXPORT DMA1_Channel4_IRQHandler [WEAK] EXPORT DMA1_Channel5_IRQHandler [WEAK] EXPORT DMA1_Channel6_IRQHandler [WEAK] EXPORT DMA1_Channel7_IRQHandler [WEAK] EXPORT ADC1_IRQHandler [WEAK] EXPORT EXTI9_5_IRQHandler [WEAK] EXPORT TIM1_BRK_TIM15_IRQHandler [WEAK] EXPORT TIM1_UP_TIM16_IRQHandler [WEAK] EXPORT TIM1_TRG_COM_TIM17_IRQHandler [WEAK] EXPORT TIM1_CC_IRQHandler [WEAK] EXPORT TIM2_IRQHandler [WEAK] EXPORT TIM3_IRQHandler [WEAK] EXPORT TIM4_IRQHandler [WEAK] EXPORT I2C1_EV_IRQHandler [WEAK] EXPORT I2C1_ER_IRQHandler [WEAK] EXPORT I2C2_EV_IRQHandler [WEAK] EXPORT I2C2_ER_IRQHandler [WEAK] EXPORT SPI1_IRQHandler [WEAK] EXPORT SPI2_IRQHandler [WEAK] EXPORT USART1_IRQHandler [WEAK] EXPORT USART2_IRQHandler [WEAK] EXPORT USART3_IRQHandler [WEAK] EXPORT EXTI15_10_IRQHandler [WEAK] EXPORT RTCAlarm_IRQHandler [WEAK] EXPORT CEC_IRQHandler [WEAK] EXPORT TIM12_IRQHandler [WEAK] EXPORT TIM13_IRQHandler [WEAK] EXPORT TIM14_IRQHandler [WEAK] EXPORT TIM5_IRQHandler [WEAK] EXPORT SPI3_IRQHandler [WEAK] EXPORT UART4_IRQHandler [WEAK] EXPORT UART5_IRQHandler [WEAK] EXPORT TIM6_DAC_IRQHandler [WEAK] EXPORT TIM7_IRQHandler [WEAK] EXPORT DMA2_Channel1_IRQHandler [WEAK] EXPORT DMA2_Channel2_IRQHandler [WEAK] EXPORT DMA2_Channel3_IRQHandler [WEAK] EXPORT DMA2_Channel4_5_IRQHandler [WEAK] EXPORT DMA2_Channel5_IRQHandler [WEAK] WWDG_IRQHandler PVD_IRQHandler TAMPER_IRQHandler RTC_IRQHandler FLASH_IRQHandler RCC_IRQHandler EXTI0_IRQHandler EXTI1_IRQHandler EXTI2_IRQHandler EXTI3_IRQHandler EXTI4_IRQHandler DMA1_Channel1_IRQHandler DMA1_Channel2_IRQHandler DMA1_Channel3_IRQHandler DMA1_Channel4_IRQHandler DMA1_Channel5_IRQHandler DMA1_Channel6_IRQHandler DMA1_Channel7_IRQHandler ADC1_IRQHandler EXTI9_5_IRQHandler TIM1_BRK_TIM15_IRQHandler TIM1_UP_TIM16_IRQHandler TIM1_TRG_COM_TIM17_IRQHandler TIM1_CC_IRQHandler TIM2_IRQHandler TIM3_IRQHandler TIM4_IRQHandler I2C1_EV_IRQHandler I2C1_ER_IRQHandler I2C2_EV_IRQHandler I2C2_ER_IRQHandler SPI1_IRQHandler SPI2_IRQHandler USART1_IRQHandler USART2_IRQHandler USART3_IRQHandler EXTI15_10_IRQHandler RTCAlarm_IRQHandler CEC_IRQHandler TIM12_IRQHandler TIM13_IRQHandler TIM14_IRQHandler TIM5_IRQHandler SPI3_IRQHandler UART4_IRQHandler UART5_IRQHandler TIM6_DAC_IRQHandler TIM7_IRQHandler DMA2_Channel1_IRQHandler DMA2_Channel2_IRQHandler DMA2_Channel3_IRQHandler DMA2_Channel4_5_IRQHandler DMA2_Channel5_IRQHandler B . ENDP ALIGN ;******************************************************************************* ; User Stack and Heap initialization ;******************************************************************************* IF :DEF:__MICROLIB IMPORT __initial_sp IMPORT __heap_base IMPORT __heap_limit ELSE IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap IMPORT Stack_Size IMPORT Heap_Size IMPORT Heap_Mem IMPORT Stack_Mem LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN ENDIF END END
; Amount of memory (in bytes) allocated for Stack ; Tailor this value to your application needs ; <h> Stack Configuration ; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; <h> Heap Configuration ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 EXPORT __initial_sp EXPORT __heap_base EXPORT __heap_limit EXPORT Stack_Size EXPORT Heap_Size EXPORT Heap_Mem EXPORT Stack_Mem THUMB END
Outcome:Now i have an error when the stm32f1_md_vectors is assembled:
\..\GEZE_Framework\04_Implementation\drivers\MCU_MicrocontrollerTuning\platform_stm32f1\stm32lib\cmsis\0stm32f1_md_vectors.s", line 319 (column 32): Error: A1150E: Bad symbol, not defined or external 319 0000001e LDR R1, =(Stack_Mem + Stack_Size) ^ "..\..\..\GEZE_Framework\04_Implementation\drivers\MCU_MicrocontrollerTuning\platform_stm32f1\stm32lib\cmsis\0stm32f1_md_vectors.s", line 319: Error: A1284E: Literal pool too distant, use LTORG to assemble it within 4KB 319 0000001e LDR R1, =(Stack_Mem + Stack_Size) "..\..\..\GEZE_Framework\04_Implementation\drivers\MCU_MicrocontrollerTuning\platform_stm32f1\stm32lib\cmsis\0stm32f1_md_vectors.s", line 320 (column 33): Error: A1150E: Bad symbol, not defined or external 320 00000020 LDR R2, = (Heap_Mem + Heap_Size) ^ "..\..\..\GEZE_Framework\04_Implementation\drivers\MCU_MicrocontrollerTuning\platform_stm32f1\stm32lib\cmsis\0stm32f1_md_vectors.s", line 320: Error: A1284E: Literal pool too distant, use LTORG to assemble it within 4KB 320 00000020 LDR R2, = (Heap_Mem + Heap_Size) 4 Errors, 0 Warnings Error: Assembly error 1
dBeltran said:Till the day, we've used the default startup provided in the Standard Peripheral Library from ST.
Is it correct to say that that startup file is assembled at your end, and shipped to your customers as an object file?
dBeltran said:We need to allow the user to customize the Stack and Heap Size.
The SPACE/FILL directive to the assembler does the job of allocating the given amount of space, but such an allocation is an assembling-time activity. Once the object file is prepared, one cannot, in general, stretch the region (for e.g., by forcing an address-change) and make it larger, without also overlapping the region with the space allocated for adjacent symbols.
It seems that you want to
If so, it is too late to change the SPACE/FILL directives; the startup's source isn't available.
To support your goal, one must avoid defining the stack and heap sizes in the assembler's source. Instead, one must rely on the linker/scatter script to:
Some examples:
The above:
Edit: Hmm.. I can't downvote my own, accidental upvote without reducing the count to 0. Nevermind, I can live with whatever such self-votes are supposed to imply :)
dBeltran said:I'm just trying to assemble them and incorporate them in the .lib with the same behaviour of the original start-up.
That's just it: the step of putting the file into the library already changes the behaviour of the linker. It changes that object file from one that the linker always processes to one that will only be looked at to see if can fulfill a need that the linker knows about. If it doesn't come up in such searches, it'll never ever enter the playing field.
I think you forgot to add import directives for the pieces you transplanted out of the original startup file.
They are not variables, they are symbols, pretty sure I've IMPORTed them before
I neither use Keil nor STM parts, I use plain gcc+make on SiLabs EFM32GG series. However, this info may be useful to you...
I prebuild startup.c and system.c, as supplied by vendor, into a .a. startup.c has #defines for HEAP_SIZE and STACK_SIZE, with local defaults (as I recall, 1K stack, 3K heap).
In apps that need non-default stack or heap, we simply COPY the startup.c to the local project, name it in our dependencies, e.g.
app.axf: app.o startup.o
and supply a define (a target-specific variable actually, for those that know GNU make well)
startup.o : CPPFLAGS += -D__HEAP_SIZE=0x2000
We don't actually need to EDIT the copied startup.c at all, just merely have it locally. I have found that with the gcc toolchain, a .o on the cmd line overrides a .o found in a .a.
I can verify from my app.map file that my heap would indeed be 0x2000.
I see that your start up file is in assembler. I imagine my usage pattern would still work for me, after all, make has rules for building a .o from a .c but also from a .s.
Stuart
