Issues linking the startup file in a precompiled .lib
Background
On our company, we precompile our platform library into a .lib and provide these library to other developers.
Till the day, we've used the default startup provided in the Standard Peripheral Library from ST.
Goal
We need to allow the user to customize the Stack and Heap Size.
What we have tried
For this example we're using and STM32F103RB(Nucleo Board).
I've tried to split the startup we've been using in two; one will carry the Heap and Stack definitions and the other will be contain the vector definitions.
The file with the vectors definitions(stm32f1_md_vectors.s) will be included in the .lib file and the other will be linked by the Application developer and together with hiw own code and the .lib file.
These are the milestones I propose:
0) Compile the .lib and link it to an application to obtain the map.
1) Split the startup file in two
2) Assemble them and ensure they work together in the same way than the single startup
3) Assemble them and incorporate them into the .lib and ensure it works like point 2)
4) Assemble the vector stm32f1_md_vectors.s and incorporate in the .lib. Assemble the startup.s and link with the application and the .lib
This is the code I'm using:
Code of the startup.s:
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; <h> Stack Configuration
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000200
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
Code of the stm32f1_md_vectors.s file:
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                IMPORT __initial_sp
				EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp                    ; Top of Stack
                DCD     Reset_Handler                   ; Reset Handler
                DCD     NMI_Handler                     ; NMI Handler
                DCD     HardFault_Handler               ; Hard Fault Handler
                DCD     MemManage_Handler               ; MPU Fault Handler
                DCD     BusFault_Handler                ; Bus Fault Handler
                DCD     UsageFault_Handler              ; Usage Fault Handler
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     SVC_Handler                     ; SVCall Handler
                DCD     DebugMon_Handler                ; Debug Monitor Handler
                DCD     0                               ; Reserved
                DCD     PendSV_Handler                  ; PendSV Handler
                DCD     SysTick_Handler                 ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler                 ; Window Watchdog
                DCD     PVD_IRQHandler                  ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler               ; Tamper
                DCD     RTC_IRQHandler                  ; RTC
                DCD     FLASH_IRQHandler                ; Flash
                DCD     RCC_IRQHandler                  ; RCC
                DCD     EXTI0_IRQHandler                ; EXTI Line 0
                DCD     EXTI1_IRQHandler                ; EXTI Line 1
                DCD     EXTI2_IRQHandler                ; EXTI Line 2
                DCD     EXTI3_IRQHandler                ; EXTI Line 3
                DCD     EXTI4_IRQHandler                ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler        ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler        ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler        ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler        ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler        ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler        ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler        ; DMA1 Channel 7
                DCD     ADC1_IRQHandler                 ; ADC1
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     EXTI9_5_IRQHandler              ; EXTI Line 9..5
                DCD     TIM1_BRK_TIM15_IRQHandler       ; TIM1 Break and TIM15
                DCD     TIM1_UP_TIM16_IRQHandler        ; TIM1 Update and TIM16
                DCD     TIM1_TRG_COM_TIM17_IRQHandler   ; TIM1 Trigger and Commutation and TIM17
                DCD     TIM1_CC_IRQHandler              ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler                 ; TIM2
                DCD     TIM3_IRQHandler                 ; TIM3
                DCD     TIM4_IRQHandler                 ; TIM4
                DCD     I2C1_EV_IRQHandler              ; I2C1 Event
                DCD     I2C1_ER_IRQHandler              ; I2C1 Error
                DCD     I2C2_EV_IRQHandler              ; I2C2 Event
                DCD     I2C2_ER_IRQHandler              ; I2C2 Error
                DCD     SPI1_IRQHandler                 ; SPI1
                DCD     SPI2_IRQHandler                 ; SPI2
                DCD     USART1_IRQHandler               ; USART1
                DCD     USART2_IRQHandler               ; USART2
                DCD     USART3_IRQHandler               ; USART3
                DCD     EXTI15_10_IRQHandler            ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler             ; RTC Alarm through EXTI Line
                DCD     CEC_IRQHandler                  ; HDMI-CEC
                DCD     TIM12_IRQHandler                ; TIM12
                DCD     TIM13_IRQHandler                ; TIM13
                DCD     TIM14_IRQHandler                ; TIM14
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     0                               ; Reserved
                DCD     TIM5_IRQHandler                 ; TIM5
                DCD     SPI3_IRQHandler                 ; SPI3
                DCD     UART4_IRQHandler                ; UART4
                DCD     UART5_IRQHandler                ; UART5
                DCD     TIM6_DAC_IRQHandler             ; TIM6 and DAC underrun
                DCD     TIM7_IRQHandler                 ; TIM7
                DCD     DMA2_Channel1_IRQHandler        ; DMA2 Channel1
                DCD     DMA2_Channel2_IRQHandler        ; DMA2 Channel2
                DCD     DMA2_Channel3_IRQHandler        ; DMA2 Channel3
                DCD     DMA2_Channel4_5_IRQHandler      ; DMA2 Channel4 & Channel5
                DCD     DMA2_Channel5_IRQHandler        ; DMA2 Channel5
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
     IMPORT  __main
     IMPORT  SystemInit
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                      [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler                [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler                [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler                 [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler               [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                      [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler                 [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler                   [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler                  [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler                  [WEAK]
                EXPORT  PVD_IRQHandler                   [WEAK]
                EXPORT  TAMPER_IRQHandler                [WEAK]
                EXPORT  RTC_IRQHandler                   [WEAK]
                EXPORT  FLASH_IRQHandler                 [WEAK]
                EXPORT  RCC_IRQHandler                   [WEAK]
                EXPORT  EXTI0_IRQHandler                 [WEAK]
                EXPORT  EXTI1_IRQHandler                 [WEAK]
                EXPORT  EXTI2_IRQHandler                 [WEAK]
                EXPORT  EXTI3_IRQHandler                 [WEAK]
                EXPORT  EXTI4_IRQHandler                 [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler         [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler         [WEAK]
                EXPORT  ADC1_IRQHandler                  [WEAK]
                EXPORT  EXTI9_5_IRQHandler               [WEAK]
                EXPORT  TIM1_BRK_TIM15_IRQHandler        [WEAK]
                EXPORT  TIM1_UP_TIM16_IRQHandler         [WEAK]
                EXPORT  TIM1_TRG_COM_TIM17_IRQHandler    [WEAK]
                EXPORT  TIM1_CC_IRQHandler               [WEAK]
                EXPORT  TIM2_IRQHandler                  [WEAK]
                EXPORT  TIM3_IRQHandler                  [WEAK]
                EXPORT  TIM4_IRQHandler                  [WEAK]
                EXPORT  I2C1_EV_IRQHandler               [WEAK]
                EXPORT  I2C1_ER_IRQHandler               [WEAK]
                EXPORT  I2C2_EV_IRQHandler               [WEAK]
                EXPORT  I2C2_ER_IRQHandler               [WEAK]
                EXPORT  SPI1_IRQHandler                  [WEAK]
                EXPORT  SPI2_IRQHandler                  [WEAK]
                EXPORT  USART1_IRQHandler                [WEAK]
                EXPORT  USART2_IRQHandler                [WEAK]
                EXPORT  USART3_IRQHandler                [WEAK]
                EXPORT  EXTI15_10_IRQHandler             [WEAK]
                EXPORT  RTCAlarm_IRQHandler              [WEAK]
                EXPORT  CEC_IRQHandler                   [WEAK]
                EXPORT  TIM12_IRQHandler                 [WEAK]
                EXPORT  TIM13_IRQHandler                 [WEAK]
                EXPORT  TIM14_IRQHandler                 [WEAK]
                EXPORT  TIM5_IRQHandler                  [WEAK]
                EXPORT  SPI3_IRQHandler                  [WEAK]
                EXPORT  UART4_IRQHandler                 [WEAK]
                EXPORT  UART5_IRQHandler                 [WEAK]
                EXPORT  TIM6_DAC_IRQHandler              [WEAK]
                EXPORT  TIM7_IRQHandler                  [WEAK]
                EXPORT  DMA2_Channel1_IRQHandler         [WEAK]
                EXPORT  DMA2_Channel2_IRQHandler         [WEAK]
                EXPORT  DMA2_Channel3_IRQHandler         [WEAK]
                EXPORT  DMA2_Channel4_5_IRQHandler       [WEAK]
                EXPORT  DMA2_Channel5_IRQHandler         [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_IRQHandler
EXTI9_5_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
CEC_IRQHandler
TIM12_IRQHandler
TIM13_IRQHandler
TIM14_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_DAC_IRQHandler
TIM7_IRQHandler
                B       .
                ENDP
                ALIGN
				END
And the scatter:
LR_IROMPROGRAM1 0x08000000 0x1C800  {    ; load region size_region
   ER_IROM1 0x08000000 0x1C800 {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x20000000 0x00010000  {  ; RW data
   .ANY (+RW +ZI)
LR_IROMDATA1 0x0801F800 0x800  {    ; load region size_region
   ER_EMPTY1 0x0801F800 EMPTY 0x800  {
     ;Empty region not zero-initialized in run time
Outcome
2) It works when I compile the files together in a sample project.
3) It succeds in incorporating them in the.lib , but when I try to link them with the application, it seems the RESET area isn't found. This is the linker output:
"..\..\.\output\generated\gf_hal.sct", line 10 (column 9): Error: L6236E: No section matches selector - no section to be FIRST/LAST.
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 1 error messages.
Error: Linker error 1
I attach three maps: the one obtained in the steps 0, 2 and 3.
Tomorrow I'll try to reproduce the steps 2 and 3 with a minimal library(and no propetary code) so I can provide sample projects.
  • I neither use Keil nor STM parts, I use plain gcc+make on SiLabs EFM32GG series.  However, this info may be useful to you...
    I prebuild startup.c and system.c, as supplied by vendor, into a .a. startup.c has #defines for HEAP_SIZE and STACK_SIZE, with local defaults (as I recall, 1K stack, 3K heap).
    In apps that need non-default stack or heap, we simply COPY the startup.c to the local project, name it in our dependencies, e.g.
    app.axf: app.o startup.o
    and supply a define (a target-specific variable actually, for those that know GNU make well)
    startup.o : CPPFLAGS += -D__HEAP_SIZE=0x2000
    We don't actually need to EDIT the copied startup.c at all, just merely have it locally.  I have found that with the gcc toolchain, a .o on the cmd line overrides a .o found in a .a.
    I can verify from my app.map file that my heap would indeed be 0x2000.
    I see that your start up file is in assembler. I imagine my usage pattern would still work for me, after all, make has rules for building a .o from a .c but also from a .s.
    Stuart
    Stuart
