I have the following error:
Device 'STMicroelectronics::STM32L476RGTx' is not supported by Toolchain ! ***.
The TM32L4xx_FDP pack is up to date in the pack installer.
The device is supported in ths pack.
What to do next?
Are you using the free version of Keil for ST's Cortex M0-based chips?
https://www2.keil.com/stmicroelectronics-stm32/mdk
Complains when you load the project, but does build
STM32Cube_FW_L4_V1.15.1\Projects\NUCLEO-L476RG\Examples\CRC\CRC_UserDefinedPolynomial
Can select the STM32L476RGTx in Device option, project loads/builds without complaint.
Yes, i already found that the license is only for m0+
What licence do i need for the L4?
I dont see the L4 in the list,only the L0 and the G0
EVersteeg said:What licence do i need for the L4
Same as for any other Cortex-M4 - there is no special deal for that.
See above - that's because you have the M0-only version!
You either need to uninstall the LIC so that the MDK reverts back to eval version:
http://www.keil.com/support/man/docs/license/license_sul_uninstall.htm
or Buy a MDK license as per your requirements:
http://www2.keil.com/mdk5/selectorTo get a quote, contact the local distributor:http://keil.com/distis
