Hello to all scientist . can anybody help me in SSD1306 OLED for LPC1768???
I need library...
please help me ... thank you
I2C or SPI ?
Find a generic SSD1306 library, and fix the hardware interface layer to match your micro-controller. Porting shouldn't be at all hard. Widen the search, and find a clean implementation you like.
i am not so talented for porting, i need i2c ssd1306 for LPC1768 example. thank you for supporting me
So, again: https://www.lmgtfy.com/?q=SSD1306+LPC1768
It is not Rocket Science, it is a matter of finding close equivalents, and doing a cut-n-paste-edit so the parts bolt together.
Find I2C examples for your platform, like an EEPROM or Temperature Sensor, or whatever. Use that as your starting point for your I2C side, change address to match that of the SSD1306 (see other examples), and register access / block write.
Find a SSD1306 library, got to be a few of them across multiple targets, analyse how the MCU level abstraction has been done, and stitch it to your LPC1768 I2C layer.
Find a friend, lecturer or colleague with suitable competence to assist you locally.
Hi Andy... I Couldn't find any Example at your links.
