Hi everyone
I am trying to start with my STM32F100RBT6B in the STM32VLDiscovery and programming in Keil uVision IDE, with Cube MX. I upload the CubeMX code for the uVision and finished the code with 0 Errors and 0 Warnings, but when i try to Download the code to flash memory it replies with this:
and then the flash download fail.
i would be very grateful for the one who helps me in here.
PS: Using the internal STLink with the USB cable.
The VL Discovery is very old, probably not going to be well supported by current tools. Check you have most current firmware for it.
The Segger J-Link OB firmware doesn't work on the ST-LINK/V1 used on the VL board.
You could connect a J-LINK, uLink, or ST-LINK/V2 or V3 via pins on the board
https://www.segger.com/downloads/application-notes/AN00021
Consider getting a NUCLEO-64 board
Westonsupermare Pier said:probably not going to be well supported by current tools
ISTR a thread recently about disappearing support for ancient STLinks ... ?
Westonsupermare Pier said:Consider getting a NUCLEO-64 board
+1
DvdZk - Go to the Product Page:
https://www.st.com/en/microcontrollers-microprocessors/stm32f100rb.html
Choose the 'Tools & Software' Tab.
Scroll down to 'Product Evaluation Tools'
It's there!
Andy Neil said:ISTR a thread recently about disappearing support for ancient STLinks ... ?
Found it:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/45556/command-not-supported-during-download-with-keil-mdk-arm-v5-29/162844#162844
