The hex file ouput of keil and Softconsole are different.
After loading the keil hex file into flashpro and programming it to a2f-eval-kit, there is no output displayed on UART.
But the functionality is proper with softconsole hex file.
From what i have read, both of them produce intel hex file as output.
How to get the same output as that of softconsole using Keil.
Andy Neil said:Have you tried using the debugger to see where it is failing ?
naren_v said:No.I haven't
Why not ?
There is a lot more to software development than just writing code!
It is your job to test & debug your code - it's no use just throwing up your hands, saying "it doesn't work" - and expecting others to fix it for you.
How To Debug
You have a big advantage here, as you have an example that works, and one that doesn't - so you can compare & contrast to see where the non-working one differs ...
