Lately I'd obsessed over compiling STM32 project with ARMCLANG.
Here is Details:
Case 1. Used "#include <sstream>" in cpp file, complied successfully but execute failed, meanwhile I didn't use any function in <sstream>.
Case 2. Comment this code, project is fine.
Environment:
IDE: MDK 5.2.5
Compiler: armclang v6.9
SRC: c/c++ file.
Board: stm32f4 series(CPU Cortex-M4, Arch armv7-M).
sstream_compile_failed said:SRC: c/c++ file.
Surely, a file must be either C or C++ ?
So which is it?
I mean project including both of c and c++. In case 1 I indicate that is cpp file.
But still, any one source file can only be either C or C++
Can you successfully build a purely C++ project?
There are plenty of references on the general principles of mixing C and C++ source in a project - not specific to Keil or ARM.
It's generally best to make your project a C++ project - ie, your main() function is a C++ one - to ensure that you get all the required C++ support. Then you add C files to it, using the usual approach - such as
extern "C" {
etc
See, for example, https://stackoverflow.com/questions/1041866/what-is-the-effect-of-extern-c-in-c
Thanks for your response, but it's unrelated. I just find the problem: use iostream series function in c++ files without disabling “Half Host Mode”, will result in this issue. I add "__asm(".global __use_no_semihosting");" in the head of main.cpp then the compiler comes out errorr. Then I redefined related functions(eg. fflush(), fgetc()). Now my project works fine.
sstream_compile_failed said:Half Host Mode
You mean semihosting ?
http://www.keil.com/support/man/docs/armcc/armcc_pge1358787046598.htm
