Hi, when I try to open MDK- ARM uVision 5.29. A Dialog Box pops up that says >>> TOOLS.INI - SECTION '[C51]': missing 'PATH' entry ! <<<
The software does not open at all. Only Pack Installer opens.
Can someone help me resolve this?
Is this a new installation ?
If not, what have you changed?
Most likely either the MDK installation is corrupt or you are trying to open a C51 project in MDK.MDK and C51 are 2 different toolchains and are targeting different target devices.MDK supports Cortex-M based devices and C51 supports 8051 based devices.So, you need to be careful with the target device and choice of toolchains.
Yes, I'm installing this for the first time
I click on the shortcut on the desktop that is automatically created after installation. Also, I don't change anything during the Installation Wizard. The device that I use is an STM32F401RE, for which I install the required files in Pack Installer.
Do you have a section in the Tools.ini file (Keil installation folder) which states something like "[C51]" ?
If yes, then I would suggest removing this section -> save the file and restart uVision.In case it does not help, open a support case by following the instructions in below link and attach the Tools.ini file:http://www2.keil.com/support/silver?P=&V=&S=
Ok, I got it working, I downgraded the uVision version, set up my device on it, and then reinstalled uVision 5.29 and it works now! Thanks !
Will do, thanks!
