I need to use a library that relies on FLASH_Unlock and functions following it, however upon calling that function I get an error saying the function is invalid in C99. The library I use has an example file which is written in mdk v4 and works just fine. Is there a way I can use FLASH_Unlock() function?
Broman3100 said:I need to use a library that relies on FLASH_Unlock
What library, exactly?
Broman3100 said: I get an error saying the function is invalid in C99
Copy & paste the full, unabridged build output, and show the section of source code where the error is reported.
(for the build output, just use steps 1 & 2).
sorry for late reply, as you can see the error message I get on the code itself is different
Also st did provide clear example, but I cannot use it as a template as it is in mdk v4 and I'm using v5
The problem is still the fact that you haven't provided the declaration.
C99 will not let you get away with that.
That's what you need fix - as already described.
could you please tell me how to do that? Sorry for asking a lot my programming skills are basically very low.
Then you really need to work on your programming skills first.
See: https://www.avrfreaks.net/comment/2843566#comment-2843566
http://c-faq.com/decl/decldef.html
Thanks for you help!
I'm afraid teaching programming basics is outside the scope of this forum.
