ARM CC notify (R203(8): EVALUATION PERIOD EXPIRED for every source file. Delete license line in TOOLS.INI is ok for compilation, but not linking (32 kB limit)
Error code
Product: MDK-ARM Cortex-M0/M0+ 256k 5.28Component: ARM Compiler 5.06 update 6 (build 750)Tool: ArmCC [4d3637]compiling LPS22HB_Driver.c...Error: C9555E: Failed to check out a license.LICENSE ERROR (R203(8): EVALUATION PERIOD EXPIRED)Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: www.keil.com/.../license_management.htm If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Keil_v5\ARM\sw\mappings - Toolchain location: C:\Keil_v5\ARM\ARMCC\Bin - Selected tool variant: mdk_cm0_256k - Checkout feature: LIC0=3A...-.....-..... - Feature version: 5.0201709 - Keil error code: 1
Activation license
Thank you for licensing your Keil product. Your License ID Code (LIC) is printed below. Print a copy of this e-mail to keep for your records.MDK-ARM Cortex-M0/M0+ 256KFor ST OnlySupport Ends 31 Jan 2020PC Description : MY HP PROBOOKComputer ID (CID): CL9T1-8NMUM
Dear Customer,due to a mistake in our database, the free-to-use MDK-Essential license for STM32 devices with Cortex-M0 cores ceased to work beginning of January 2020. We have created a new serial number T0D7S-LFI5J-XKYTX for you.This number is already published on the usual page:www2.keil.com/.../mdkWe're sorry for the inconvenience.Best regards,
