I cannot compile project where arm_math.h included:
Added"Options for Target" > "C/C++" > "Defines":
C/C++ :- ARM_MATH_CM4 - __FPU_PRESENT = 1
But cannot compile
Error: L6218E: Undefined symbol arm_pid_init_f32 (referred from main.o).
Thank you for answer.I`ve added following to main.c and compiled successfully and PID starts to work:
void arm_pid_init_f32( arm_pid_instance_f32 * S, int32_t resetStateFlag) { /* Derived coefficient A0 */ S->A0 = S->Kp + S->Ki + S->Kd; /* Derived coefficient A1 */ S->A1 = (-S->Kp) - ((float32_t) 2.0 * S->Kd); /* Derived coefficient A2 */ S->A2 = S->Kd; /* Check whether state needs reset or not */ if(resetStateFlag) { /* Clear the state buffer. The size will be always 3 samples */ memset(S->state, 0, 3u * sizeof(float32_t)); } }
