Hello everyone,
I'm developing an application which has to save some file to a SD Card.
I'm using the FAT File System in MDK -ARM with a my own board.
At the moment I have some problem writing file into the SD Card.
I read some posts which suggested to drecrease the clock of the MCI peripheral.
I tried to decrease the clock and now I can write files into the SD Card.
The strange thingh is that in order to be able to write files into the SD Card I set the PCLKDIV to 8, but 8 is not a permit value.
Permitted value are 0, 1, 2, 4.
Can someone explain me how it it possible, and what I'm doing wrong?
And how can I decrease the clock of the MCI setting the field CLKDIV of CLOCK register?
Thanks a lot in advance.
Giovanni.
You haven't said what chip you're using - so impossible to say what quirks "PCLKDIV" might have on that particular part!
And such things have nothing to do with Keil or ARM!
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
