I started out learning Thumb 2 , to program for the ARM Cortex M, and ended up buying a book on ARM
assembly language, cuz I assumed it would be the same instruction set, but this book uses the GAS Syntax for the GNU Assembler, which they say is different from ARM syntax works on a wide variety of architectures.
Of course, I have nothing against playing around with both instructions sets as I
fairly new to Assembly language, and would like to get a feel for changing environments
Which of course has me wondering about the Keil Assembler, and what instruction sets
it can support.
Is it just matter of choosing a different directive at the start, like instead a A THUMB directive, it would be GAS or GNU or GNU ARM
or whichever the directive is fir instruction sets that Keil supports?
And is there is list somewhere of which instruction sets Keil supports?
Seem to recall Mazidi using Keil / ARM syntax,
https://www.amazon.com/Assembly-Language-Programming-Architecture-books/dp/0997925906
Generally speaking with assembler level programming you're trying to understand coding at the machine's level, once you've done that the skills are pretty portable, and you then have to address the syntactic differences in toolsets and how those evolve over time. In-line assembly within C is also usually non-portable and evolving. What you end up having to use may be dictated by project decisions made years earlier.
Learn the underlying skill, learn to morph what you have into what you need..
Absolutely: the thing to learn is the underlying principles - implementation details like syntax can always be looked-up.
