What instruction sets can the Keil Assembler assemble?
I started out learning Thumb 2 , to program for the ARM Cortex M, and ended up buying a book on ARM
assembly language, cuz I assumed it would be the same instruction set, but this book uses the GAS Syntax for the GNU Assembler, which they say is different from ARM syntax works on a wide variety of architectures.
Of course, I have nothing against playing around with both instructions sets as I
fairly new to Assembly language, and would like to get a feel for changing environments
Which of course has me wondering about the Keil Assembler, and what instruction sets
it can support.
Is it just matter of choosing a different directive at the start, like instead a A THUMB directive, it would be GAS or GNU or GNU ARM
or whichever the directive is fir instruction sets that Keil supports?
And is there is list somewhere of which instruction sets Keil supports?
Parents Reply
  • it’s gonna be up to the assembler in what  syntax it understands
    Of course!
    Because the source code is the input to the assembler - so it must have the syntax that the assembler accepts!
    If the Gas assembler works with many architectures i was hoping tgat Keil would to
    But the target architectures define the machine code - not the source!
    use the gas syntax in keil
    Keil is just a company.
    Again, the Keil IDE is called uVision.
    By default, uVision uses the ARM toolchain - but it can also work with GNU
