Newbie
I'm just trying out Keil, so please forgive stupid questions.
I bought an STM32F7508-DK board. To determine if the free MDK5 Keil IDE and board are working, I modified an STM example project, reducing it to turning on an LED on the board. Here is the main program:
//static void LCD_Config(void);
static void SystemClock_Config(void);
static void Error_Handler(void);.............................. this has been reduced to just a return, i.e. it does nothing.
int main(void)
  HAL_Init();
  SystemClock_Config();        // Configure the system clock to 200 MHz .... this is part of the STM example
  BSP_LED_Init(LED1);            // Configure LED1
    while (1)
        BSP_LED_On(LED1);
Console output is:
compiling main.c...
../Src/main.c(37): warning:  #177-D: function "LCD_Config"  was declared but never referenced....I commented out the call to this function
../Src/main.c: 1 warning, 0 errors
linking...
Program Size: Code=2740 RO-data=528 RW-data=16 ZI-data=1024
FromELF: creating hex file...
"STM32F7508-DISCOVERY\Exe\Project.axf" - 0 Error(s), 1 Warning(s).
Build Time Elapsed:  00:00:10
Load "STM32F7508-DISCOVERY\\Exe\\Project.axf"
Error: Flash Download failed  -  Target DLL has been cancelled..... for some reason, some of the USB ports on my laptop don't connect to ST-Link on the target board
Flash Load finished at 11:21:09...... this USB port did connect to ST-Link on the target board
Erase Done.
Programming Done.
Verify OK.
Flash Load finished at 11:21:21
An LED on the target board near the ST-Link USB connector flashes red and green, but LED1 never turns on when I press the Start/Stop Debug Session icon on the IDE.
Question: Maybe I am not using the IDE correctly (since this is my first try), or maybe the target board is broken. Is there any way of finding out?
Thanks.
