I want to set the BOR level on my project (I'm using a STM32L496). Is it possible ?
Best regards
Riccardo
thank you for your response.
I was able to add the OPT.s file to my project but I'm not able to start the wizard or use the file to configure the BOR.
There is any guide or example that explain how to use that file or the wizard ?
Thank you
This might be helpful: "STM32 FLASH OPTION BYTES PROGRAMMING"
http://www.keil.com/support/docs/3406.htm
See also:
Chapter 3.6 of the "STM32 ST-LINK utility software description":
https://www.st.com/content/ccc/resource/technical/document/user_manual/e6/10/d8/80/d6/1d/4a/f2/CD00262073.pdf/files/CD00262073.pdf/jcr:content/translations/en.CD00262073.pdf
