Keil Error: L6218E undefined symbol to *a struct*
I am trying to compile my code but I am ending up with ERROR: L6218E : Undefined symbol Bit (referred from main.o).
Where Bit is a struct that I am using to store boolean values. For eg:
In variable.h file
struct
	unsigned bPowerONStatus : 1;
	unsigned bTimerONStatus : 1;
} extern Bit;
In main.c file:
#include variable.h
int main()
	while(1)
		ReadTimerStatus();
		if(Bit.bPowerONStatus)
			// System is ON
		else
			// System if OFF
In PowerChecker.c file
#include variable.h
void ReadTimerStatus(void)
	if(Bit.bTimerONStatus)
		Bit.bPowerONStatus = 1;
	else
		Bit.bPowerONStatus = 0;
What am I doing wrong here? What is the correct method of defining a struct which will be used in multiple source files?
