I am trying to compile my code but I am ending up with ERROR: L6218E : Undefined symbol Bit (referred from main.o).
Where Bit is a struct that I am using to store boolean values. For eg:
In variable.h file
struct { unsigned bPowerONStatus : 1; unsigned bTimerONStatus : 1; } extern Bit;
In main.c file:
#include variable.h int main() { while(1) { ReadTimerStatus(); if(Bit.bPowerONStatus) { // System is ON } else { // System if OFF } } }
In PowerChecker.c file
#include variable.h void ReadTimerStatus(void) { if(Bit.bTimerONStatus) { Bit.bPowerONStatus = 1; } else { Bit.bPowerONStatus = 0; } }
What am I doing wrong here? What is the correct method of defining a struct which will be used in multiple source files?
