Keil Error: L6218E undefined symbol to *a struct*
I am trying to compile my code but I am ending up with ERROR: L6218E : Undefined symbol Bit (referred from main.o).
Where Bit is a struct that I am using to store boolean values. For eg:
In variable.h file
struct
	unsigned bPowerONStatus : 1;
	unsigned bTimerONStatus : 1;
} extern Bit;
In main.c file:
#include variable.h
int main()
	while(1)
		ReadTimerStatus();
		if(Bit.bPowerONStatus)
			// System is ON
		else
			// System if OFF
In PowerChecker.c file
#include variable.h
void ReadTimerStatus(void)
	if(Bit.bTimerONStatus)
		Bit.bPowerONStatus = 1;
	else
		Bit.bPowerONStatus = 0;
What am I doing wrong here? What is the correct method of defining a struct which will be used in multiple source files?
  • The correct way is to actually define it.  Once, in a single source file.  So far, you've only managed to declare it.  If the difference between those two terms isn't clear to you, you'll have to get back to your learning materials.
