I have a TIVA launchpad TM4C123GHPM. I was able to Debug the board/code with IAR and CCS. With uVision, when i go to Debug tab, I do not see the Stellaris ICDI option from the dropdown to select the ICDI. I am using uVision 5. I do see CMSIS-DAP Debugger option but no Stellaris ICDI. Am i missing anything during the uVision installation? Please advise.
Hello kilo,
we have created an add-on installer that you can use to get back Stellaris ICDI support in MDK: http://www.keil.com/support/docs/4196.htm
Kind regards,
Christopher
Hi Christopher,
I have downloaded and run the exe file linked in the support docs 4196.htm. However I cannot see the Stellaris ICDI under the debug TAb in the options for Target 1 dialog.
Are there additional steps required after running the exe file?
Regards
Peter
Hi Peter,
there are no additional steps necessary. Just run this installer which is attached to our knowledgebase article www.keil.com/support/docs/4196.htm and specify the correct MDK installation path.
This installer copies the uVision driver (lmidk-agdi.dll) for this debug interface into the BIN folder and also adds it to the Tools.ini file. I tested it with a genuine MDK 5.29 installation and after that I was able to select the 'Stellaris ICDI' debugger in the 'Options for Target - Debug' dialog.
Hans
Hi Hans,
I have the same issue as Peter in that the 'stellaris ICDI' debugger doesn't show up in the debug tools even after running the add-on installer.
Following your hints above, I manually copied the lmidk-agdi.dll (from a keil v4 installation) into the BIN folder, and edited the Tools.ini to include the line, but still can't get it working. What else could be the issue?
PS:I've also installed the legacy support pack but that didn't help either. I'm using the Tiva C launchpad board from TI.
Ah, I've figured it out. I hadn't changed the installation directory! Should've been D:\Keil_v5 instead of C:\Keil_v5.
Thanks!
