even I did dialog --suppress , my builds are failed due to " "Failed to move or copy license cache file from source to destination "
No more select any name that might indicate you are a member of Arm!
As obviously you possess a registered license:
1. Open a Support Ticket: http://www2.keil.com/support/silver
2. Refer to this Forum entry
3. Explain the problem and
4. Confirm the Keil product and version in use
just now Changed name.
before we answer: can you please identify yourself - you are naming yourself "arm support"
Thanks for quick response . but I need one more information . How to check license taking from server or Not ?
Does this - I guess warning - still come up if you stop scanning the corresponding directory for viruses? (We had a similar request at Keil Support some months ago)
Another recommendation - use the latest version of Arm Compiler 6:
https://developer.arm.com/tools-and-software/embedded/arm-compiler/downloads/version-6
