even I did dialog --suppress , my builds are failed due to " "Failed to move or copy license cache file from source to destination "
Thanks for quick response . but I need one more information . How to check license taking from server or Not ?
before we answer: can you please identify yourself - you are naming yourself "arm support"
just now Changed name.
No more select any name that might indicate you are a member of Arm!
As obviously you possess a registered license:
1. Open a Support Ticket: http://www2.keil.com/support/silver
2. Refer to this Forum entry
3. Explain the problem and
4. Confirm the Keil product and version in use
