Keil mdk-arm NUCLEO-G474RE flash programmed error
Hello
At the development board NUCLEO-G474RE v Keil (tested version 5.24 and 5.29) flash memory cannot be programmed, when is set in Flash Download checkbox "Erase Sectors".
When is set in Options->debug->ST-Link Debugger settings->Flash Download checkbox "Erase Full Chip" all is ok.
Someone solved similar problem?
