So, i am using a development board with a C8051F388.
the problem is, i was trying to use the serial port via USB to connect to PC, and use a terminal to see what it was outputting, but when i try to choose the COM port, it does not show that i connected
Every time i plug it to PC it shows a windows message
and when i go to the Device Manager it show that the device was not recognized
it is in PT. is says "Unknown USB device" and in Properties shows a error called (code 43)
the board uses a FT230XS-R FTDI driver. I already installed all drivers but still cant solve the problem.
p.s. at moment the board is only using the USB plug to use the serial port. the power and flashing is handled by a USB Debug adapter.
Ty
Tanks to everyone,
i already did what you recommended but it did not worked, so i will try to ask on silicon lab forum as you suggested
Ty once again for your time
